Descrizione: Descrizione: http://www.africaland.it/africaland-old.gifHIGH CAPACITY OIL SUMP LUBAMBA
ITALIAN PAGE
HIGH CAPACITY (HC) OIL SUMP FOR LT230 TRANSFER GEARBOX
Descrizione: Descrizione: http://www.africaland.org/accessori/alubam05.jpg
more cooler
more oil resistence
best lubrification on off-road!
Description:
The high capacity oil sump increases the oil capacity of liters 0,65 bringing it up to from liters 2,3 to about 3. Referring to its design we can notice that the bottom side of the of the sump is supported with a thicker and reinforced design.
Adaptability:
You can use HC oil sump into LT230 Transfer box equipped on Land Rover Defender, Discovery I & II, Range Rover up to 1989.
Benefits:
The increased oil capacity improves LT230 transfer gearbox performances at a tropical temperature, when the engine is brought up to its potential limit and it avoids LT230 overheating. Also, with a better oil capacity the Lt230 Transfer gearbox, mechanical parts duration  are longer. Maintenance and servicing of oil renewal is lesser.
Parts:
1
1
gasket
10
stainless steel bolts m8 x 20
10
stainless steel washer
fitting instruction
Tools:
17 mm socket key for drain plug
10 mm socket key to remove bottom case bolts
8 mm hexagonal key to refit new bolts
½ “ drive racket handle for level plug
drained oil container
gun oil suction
Descrizione: Descrizione: http://www.africaland.org/accessori/alubam.gif
Fitting:
refitting the new oil sump it takes less than one hour. You do not need to remove the transfer gearbox and you can make it even without the jacking beam.  The first step is to locate a container beneath the drain plug in the bottom of the gearbox casing, then screw the drain plug and allow the oil to drain.  To execute the refitting procedures please follow the figure A and B. At the end of the refitting procedures close the drain plug.  Refill the gearbox with API-GL5 hypoid oil  through the filler/level hole, until the oil level reaches the lower edge of the hole.  Remember to park the vehicle on level ground.
Descrizione: Descrizione: http://www.africaland.org/accessori/alubam01.jpgDescrizione: Descrizione: http://www.africaland.org/accessori/alubam02.jpg
Descrizione: Descrizione: http://www.africaland.it/webdata/sondaggio1/sasx.gif
 Download
Descrizione: Descrizione: http://www.africaland.it/webdata/sondaggio1/sadx.gif
Descrizione: Descrizione: http://www.africaland.org/images/video2.gif HC OIL SUMP
Descrizione: Descrizione: http://www.africaland.it/logo_pdf.gif FITTING INSTRUCTION
Descrizione: Descrizione: http://www.africaland.it/webdata/sondaggio1/sbsx.gif
Descrizione: Descrizione: http://www.africaland.it/webdata/sondaggio1/sbdx.gif
 Price
TRANSFER OIL SUMP    € 65,00 + VAT
special tanks to Silvio Vannini, Jim Attril, Andy.
This part is designed, developed, and tested to operate under extreme conditions.
ultimo aggiornamento 19-03-2008  © Africaland , all rights reserved, web design by R.Del Rosso
