SPARE PARTS
= Each vehicle must have = One per group = Optional
OIL ENGINE 3LT. OIL GEAR 1LT. BRAKE FLUID 250CC.
BALL JOINT RH #RTC5869 LH #RTC5870 P.S. #RTC4198
SET HUB BEARING #RTC3429 FTC2783 OIL-SEAL #606666
TUBE & VALVE
ENGINE BELT #ERR3287
2 SHOCK RUBBER #552818
TIP-TOP
SILICON
WIRE OF IRON
AMERICAN TAPE
POWDER TO REPAIR LOSSES TO THE COOLING SYSTEM
BULB
FUSE
ONLY FOR SPECIAL RAID
REPAIR KIT MASTER CYL. BRAKE *STC491
REPAIR KIT SERVOFRENO #NRC4772
KIT PINZA FRENI ANT. #AEU2539
REPAIR KIT MASTER CYL. CLUTCH #8G8837L
DIFFERENTIAL
REAR SHAFT RH #FRC3270 LH #FRC3271
FRONT SHAFT RH #RTC6754R LH #RTC6755
STARTER MOTOR #ERR5009
pictures from L.R. Spare Parts Manual
FORUM
