Africaland • Leggi argomento - Identificazione motori serie III
Messaggioil 28/04/2006, 12:28
Ciao a tutti, Come devo interpretare il numero si serie del monoblocco,esite una corrispondenza come per il numero ti telaio ? Scusate se la domanda per voi è stupida ma non riesco a trovare informazioni in merito. Grazie Enrich
enrich
Messaggioil 28/04/2006, 13:05
le prima 3 cifre identificano il tipo di motore, il suffisso finale il livello di modifiche dal progetto originario. 906 diesel 3MB 366 diesel 5MB 361 364 benzina 5MB 901 904 benzina 3MB dalle seguenti numerazioni i motori sono diventati metrici (non completamente): 36123672B 36407286B 36619420B Saluti. Roberto
Messaggioil 28/04/2006, 15:11
Grazie molto gentile
enrich
Messaggioil 28/04/2006, 20:46
There has been a range of engine numbers supplied to the 2.25 litre engines we have fitted in our Landies. Numbers commencing with 151 are early SII 2.25, 3 Main Bearing engines. Series IIa 1968-71, numbers commencing with 271 suffix A –J are 2.25, 3 main bearing diesel engines, as are 276 suffix A – J and 271 suffix K onwards. Numbers commencing 237 and 252 are 3 main bearing 2.25 petrol engines, of 7:1 compression ratio. The engines fitted to SIII’s are numbered as follows. (Commencing with the first 3 numbers) 901…….3 main bearing, Petrol, 8:1 compression 902…….3 main bearing, Petrol, 8:1 compression 904…….3 main bearing, Petrol, 7:1 compression 906…….suffix A – J, 3 main bearing, Diesel 951…….3 main bearing, Petrol, 8:1, military specification 952…….3 main bearing, Petrol, 7:1, military specification From 1982 onwards Land rover started using the 5 main bearing engines in their vehicles, and in fact some of the petrol engines were carried over into the early 90’s and 110’s. 361……5 main bearing, Petrol, 8:1 (36123672B onwards metric) 364……5 main bearing, Petrol, 7:1 (36407286B onwards metric) 365……5 main bearing, Petrol, 8:1, military specification And last, but by no means least, 366……5 main bearing, Diesel (36619420B onwards metric) kiwi
kiwi
