MINES MANUAL
TYPES OF MINES
Landmines can be divided into two groups: Anti-personnel (AP) and Anti-tank
(AT)
Most AP mines are designed to injure, not to kill. AP mines are divided into 4
groups.
BLAST MINES
Most blast mines are pressure activated but some can
also be tripwire activated. This type of mine relies on the blast caused by
high explosive to severely wound the foot and leg of the person who stands on
it. They normally require a bearing pressure of 3-5kg. Most of them will be
surface-laid.
FRAGMENTATION MINES
Most fragmentation mines are tripwire activated. They are placed above ground,
normally resting on a stake and made of cast iron. When activated they send
fragments of iron in all directions.
BOUNDING FRAGMENTATION MINES
They can be pressure or tripwire activated. They will be buried with only a
small part of the fuse showing. When activated, the mine will propel itself
approximately 3-1/2 feet out of the ground and then detonate, sending steel fragments
in all directions.
DIRECTIONAL FRAGMENTATION
They can be tripwire or command activated. They are
placed above ground and aimed in a particular direction. When activated, they
send hundreds of steel ball bearings in a roughly 60 degree swath. Most commonly
used in ambush, booby trap (mechanical ambush) or in perimeter defense.
AREAS MOST LIKELY TO BE MINED
Assume any area where soldiers have been active to be
mined or booby-trapped. In particular:
*Military buildings
*Roads, entrances to storage sites
*Bridges and surrounding areas
*Paths
*Railway tracks
*Abandoned buildings
*Overgrown fields
*Shady trees used by soldiers
NOTE: A road well-used by day may not be safe at night where soldiers are
active. Care should be taken approaching villages at dawn or dusk as mines are
laid for protection during dark hours.
ADVICE ON PROTECTION FROM MINES
Do not play with mines
Do not go near mines
Do not go near wounded or dead animals
Do not touch or pick up things that are unknown
Do not touch or pick up things in unlikely places
Do not go to unknown or prohibited places
ACTION ON FINDING YOURSELF IN A MINEFIELD
The first indication of being in a minefield may be
one of the following:
You may see a mine marking sign
You may see a mine
You may drive over a mine
You or one of your party may stand on a mine
IF YOU SEE A MINE OR MARKING SIGN
Stand still
Alert the rest of the group
If you can retrace your foot steps, then do so until you are out of the
minefield.
If you cannot retrace your steps, then you will need to clear a narrow path
60cm wide out of the minefield. This is done by first looking very carefully at
the ground for any signs in your proposed path. Next, you must look for
tripwires with either your hands or a light rigid stick, across the full width
of the path and up to a height of a walking man. If any are found, mark and
avoid.
Do not be tempted to step over wires as mines are laid around tripwires.
Gently feel around the ground, especially in the undergrowth for any
surface-laid mines. If anything is suspected, do not disturb, mark and avoid.
HOW TO SEARCH OUT BURIED MINES
This is done by prodding. A sharp, pointed long-bladed
instrument such as a bayonet, knife or screwdriver can be used. It would be advisable
to carry a knife of some sort when working in high-risk area. What you are
aiming to do is clear a series of footprints approximately 30cm in diameter to
enable you to walk out of the minefield. The prodder should be held at 30
degrees and pushed gently but firmly into the ground every 2cm. If any hard
objects are found, they should be marked and avoided.
Progress will be very slow, but it will get you out of the minefield. Mark
location of mines with a marking sign and report.
IF YOU DRIVE OVER A MINE
Vehicles should, where possible, always travel in
pairs with a distance of at least 50 meters between vehicles. If you drive over
an AP mine, stop. If your vehicle is still drivable, reverse out in the same
tracks as you drove in. If vehicle is inoperable, climb out of the vehicle,
without touching the ground, onto the roof and over the back, and walk out in
the vehicle tracks.
IF LEAD VEHICLE DRIVES OVER AN ANTI-TANK MINE
Rear vehicle stops.
Don't panic.
Report incident on radio, giving location and number of people in vehicle.
Drive or walk forward to damaged vehicle using the first vehicle's tracks. Care
must be taken not to drive or walk on any ground that has not been cleared.
The lead vehicle will almost certainly be overturned and moved from its
original place of detonation.
Therefore, the place of detonation to the vehicle must be considered mined. You
must clear a path to the damaged vehicle prior to attempting any rescue or
first aid.
Due to the purpose of an AT mine, the vehicle will almost certainly be
destroyed, therefore, any occupants who are not dead will be severely injured.
If there are any survivors move them away from the vehicle to a safe area.
Great care should be taken at all times only to stand on cleared ground.
DEALING WITH CASUALTIES IN A MINEFIELD
If the first sign that you are in a minefield is
somebody standing on a mine.
Do not approach casualty without clearing a safe path.
Having reached the casualty, clear a safe area around.
Give first aid.
Clear a route out of the minefield, move the casualty.
The only first aid that may be immediately available to a mine casualty is what
the casualty can administer to himself. Carry a small dressing or first aid kit
when working in a high-risk area. It may save your life. When you have
successfully extracted yourself from a minefield mark it and report it so that
it can be dealt with later.
